Work has now started in converting the old committee room to a multi gender facility for disabled persons and male toilet facilities. The room is no longer accessible due to safety and security concerns. The lock was changed late last week and someone broke off a key in the new lock, probably not knowing it had been changed. The lock has been changed again and a plate secured over it to avoid a re-occurrence of a broken key which would inhibit entry to those working in the room. No new keys will be issued at this time. When all is finished a digital lock will be installed compatible with the existing facilities.
