Swapped Duty
6 years 2 weeks ago#1827by Sue Turner
Swapped Duty was created by Sue Turner
I swapped duty, today for Wednesday 27 June, all done through dutyman (or whatever it’s called), it hasn’t registered the change on the race programme, not sure if this is an issue or not.
Sue
6 years 2 weeks ago#1829by steve peat
Replied by steve peat on topic Swapped Duty
Hi Sue,
I can't see any record of you requesting a swap in the DutyMan system, so not sure what happened there. Suggest try again and see what happens, just login to the DutyMan system and click the Request a duty swap button
Pls note this only shows up in DutyMan, the Programme on the Website does not get changed.
Regards
Steve Peat
DutyMan admin
6 years 2 weeks ago#1830by Sue Turner
Replied by Sue Turner on topic Swapped Duty
I swapped from 27 June to 11 March, it’s correct on dutyman so will probably be all ok. Thanks
6 years 2 weeks ago#1831by steve peat
aha, found you now!
I didn't look far enough back on the log file, as I guessed you'd only recently swapped.
I can see that on Jan 5th you swapped with Chris Sainsbury who is now rostered to do Galley 27th June, so that all looks to have worked
cheers
steve
