Flat tyre
4 years 7 months ago#3247by Claire Hughes
Flat tyre was created by Claire Hughes
Is it possible to change just the inner tube on a trolley wheel?
Any tips on how to get the tyre off?
(I’d get a new wheel but that’s properly stuck on!)
Attachment F058E074-53D2-415C-8C64-7A3B954BD229.jpeg not found
4 years 7 months ago#3248by Mark Elkington
Replied by Mark Elkington on topic Flat tyre
Hi Claire
I've not seen replacement inner tubes for sale  - but I have repaired them several times.  You will need to get the wheel off though (spray it with plus gas and then hit it with a big mallet).
Once the wheel is off.
- deflate the tyre
- using bicycle tyre levers or the ends of two table spoons lever the tyre over the rim on one side.  You should now have one rim of the tyre inside the wheel and one outside.
- you can now pull the inner tube out of the open side (you may need to undo a nut holding the valve in place) - fix the inner tube with a bike repair kit if its fixable
- put the deflated inner tube back in (reverse of getting it out)
- prise the rim of the tyre back on over the wheel rim - being careful to check that the inner tube isn't trapped
- inflate tyre again
If you can get the wheel off and find a temporary replacement on Sunday I could probably fix it for you after the race
Mark.
4 years 7 months ago#3249by Claire Hughes
Replied by Claire Hughes on topic Flat tyre
Thanks Mark - i’ll keep trying then - and will bring it on Sunday if i’m still stuck!
4 years 7 months ago#3251by Andy Bartram
Replied by Andy Bartram on topic Flat tyre
No eBay APP ID and/or Cert ID defined in Kunena configurationClaire,
Get some of these...
at £24.48 for two and never have to worry.
Are you sure its a puncture? As the valves tend to leak and/or the core comes apart.
Not sure you can buy just the tube as generally they come as a tyre + tube set.
Andy
4 years 7 months ago#3252by Mark Elkington
Puncture proof would be good - but most wheel barrow wheels tend to have a smaller axle than the typical dinghy launching trolley.  These seem to have a axle size of 1/2" which I'm pretty sure will be too small.  There may be others with adjustable axle size options.
Mark
4 years 7 months ago#3253by Andy Bartram
Mark, the ones specified are available with 25mm bore, so fit standard launching trolley. To see and feel some, see the committee boat bogies in the tent..
Andy
